Steakman
Jun 04, 2014Explorer
...You should think about moving to Manila. You'd be happy there. Lots of diesel crud in the air...
My point my "friend" is this. The more mandated Emissions BS that is added to diesel trucks the lower the mpgs - plainly obvious. As a result you need more fuel to go the same distance.
Seems to me that is the perfect self defeating system. And just plain STUPID. A bit like your current POTUS.
As far as my rig is concerned, I dont have the smoke switch - kiddy stuff IMO. I run a FASS, OEM and Post OEM Fuel filter to eliminate as much as possible the particulates within diesel fuel. Currently the truck is tuned such that I get the most distance out of a set amount of fuel. Soon to become even more so with the addition of an H2O/Meth injection system...which results in an even a more complete Burn (up to 98%), of the available fuel pulse which in turn reduces fuel usage again with the end result of both reduced emissions and way better mileage.
So before ya start yapping about people needing to move, ya might want to do a little research and a little bit thinking...capiche.?
stk
