marcsbigfoot20b
Aug 22, 2014Explorer
carl2591 wrote:
did finally pull the trigger and gtt the "new" truck.
2003 Ford F-250 SuperDuty, 168K, Lariet, crew cab, 6ft bed, 7.3L diesel, fiberglass camper top already installed and painted to match, and bed liner that i might get rid of and go rhino type liner.
here is the craigslist post
http://norfolk.craigslist.org/cto/4582608909.html
the leather on driver has the usual scuffing like most, and there is some oil coming down back side most likely turbo pedestal needing o-rings and such.
In drive it back from virginia beach area it does ride nice with no load and the display was showing 18.5 MPG when i got it .. I reset it when i got fuel and it settled out around 20.5 on the road.. turning off AC it would creep up to 20.7 not bad..
Now planning to
1. replace diff cover with mag-hytek alum (which i now have)
2. I got a used 6.0L trans cooler to replace do as well replace trans fluid
3. pull turbo and rebuild with 360 bearing and new o-rings and
4. get something like the WW (not the ww2) just something to help boost a bit and turbo lag.
5. get a mild tuner for econ, tow and exhaust brake function, so advise on that is cool.
6. do the usual stuff like clean the exhaust gas tube thing, etc.
this will be sitting most of the day till about 2 yrs or so, so not in a big rush.
SO i am in the CLUB now.. high five.. :)
6.0L trans cooler 32 row from Rock auto..... HUGE!! $180
