rhagfo
Oct 30, 2014Explorer III
Hybridhunter wrote:rhagfo wrote:Hybridhunter wrote:trcgolf wrote:
I am thinking of trading my 6.0 3/4 for a 3/4 diesel... I get 8 mpg towing a 10500 lb fiver. Looking for someone who tows a similar rig with a diesel to see if the upgrade can be justified.
Understand there is no comparison on power but it still comes down to economics
Lot's of fleet cost experience here.... you will save on gas, but all the numbers I've seen tell me you won't get your money back, but you may enjoy the towing experience more.
Getting cost back????
There is cost and then there is VALUE!
Yes you will get better fuel mileage with a Diesel, will it make up for the added cost, not likely.
Huge maintenance cost! Well depends on the diesel Fords are the highest, GM next, and Cummins cost the least to maintain. Yes, I can buy a 7.99 Purolator filter, but prefer the Fleetguard for about $5.00 more. I go 10,000 miles on an oil change 3 gals. of Delo 15-40 oil, fuel filter about $20.
Value, knowing you can move the load, priceless!
Your fear and ignorance of gas engines does not make them incapable or inferior.
Not incapable, just not as capable!
Too many fear Diesels due to Ford debacle with the 6.0, 6.4, and now some (likely very few) CP4 high pressure fuel pump failures on the 6.7. The issues isn't so much the pump failed, it is Ford reportedly denies the warranty claim.
I would really like to know the true percentage of failures, and the percentage of denied claims.
