smcrea
Aug 24, 2015Explorer II
Steakman wrote:
check out ...
Titan Tanks
I put one on my 2500 HD: 52 Gallons instead of the stock 29 I think it was. Polyethylene - fits in the OEM spot underneath without ANY modifications to the frame or crossmembers...Not sure of pricing in USD..couple of years ago I paid 1200 installed in Calgary (with the skid plate - also Poly as well)..well worth it in my opinion.
I also have a 30 gallon slip tank I had built for under my Aluminum Tool Box...its simply Tee'd into my fill tube and I use a 1/2" manual ball valve to drain into the Titan. I figure I can go about 1700 miles on a full fill.... MT truck though.
cheers,
stk
This is great!... THANK YOU!
50 gallons is quite an improvement on range.. especially when towing!
It's a bit pricy though!.. Can you get anything back on your old tank? and who would buy it?
