transamz9
Dec 17, 2015Explorer
justafordguy wrote:transamz9 wrote:justafordguy wrote:mikebte wrote:
Diesel Wins, except in the case you have to install a $3-5K fuel pump. Than you might loose all your savings. But it is worth the power.
Just get a old Diesel that doesn't require an expensive fuel pump. Mine only costs $150 if I ever need one. ;)
How much does your HPOP cost though? Injectors? FICM? IPR? ICP? This is what runs your fuel system. Believe me, your truck is not special.;)
I didn't say it was special, but it's been cheap to run. All the parts for the 6.0 are much cheaper than the newer diesels. An by the way the HPOPs run around $600 but I've never had to replace anything on mine because it was broke but I have done a few MODs.;)
What mods have you done to it?
