WarrenS65
Jun 27, 2022Explorer II
If your A-Liner is one of the smaller ones, you could remove the axels, hitch, etc. and build a basement frame underneath then mount it like a camper.
If you wanted to keep the option of using it as a trailer, you could modify the a-frame tongue section so it's removable and do something similar with the axel. I had a car hauler with a removable tongue so I could store it in my garage. The tongue removed right at the front of the deck. The tongue was made of 3" OD square tube and there were two 3" ID receivers on the front of the trailer.
For your idea of starting with a ladder rack and building around it, I did that a bit over a year ago. I've camped in it about a dozen times. I made the front, sides, rear, and top all removeable so I could use it as an open truck when needed.
I'd post pictures, but I don't use any photo sharing sites. If you want to them, send me a PM and I'll send you a OneDrive link.
mobilevagrant wrote:
I actually tried to build an A-Liner Truck Cabin type camper to begin with but couldn't manage it. I also don't care for canvas sides because I boondock mostly. I actually own an A-liner pull behind now(needs rebuilt) and could probably build a TC that way now but it would likely be heavier from what I can see.
