MTBob's avatar
MTBob
DIY Stable Loads?
I have a 2008 Chevy SRW 1 Ton.
I'm thinking of making my own version of Stable Loads - something to take up the space between the regular stack of leaf springs and the overload spring.
I've read a couple of older posts about guys making them for their Fords. Has anyone made these for the Chevy leaf springs?
I've looked at the new Stable Load design and that's one approach. Just wondering if anyone has done something else.
Photos?
  • I made some for my truck out of some 1/2" thick Ultra-high-molecular-weight polyethylene (UHMW) that I had scrapped from work.
    I stacked two 3"x3" squares, and mounted them using two galvanized carriage bolts. I cut a concave surface on the top block to match the shape of the spring perch on a table saw by running it perpendicular across the spinning blade. I had to make a special fence that clamped to the regular fence to do that. To get the square shoulder under the bolt head to settle into the plastic, I just torched the head a little and let it melt its way in.
    When I have time I want to make a new set with three layers, but as you can see I'll need to buy longer bolts for that.
  • you could try logging wedges.. drill through them to make a slot to clamp them on and they are available where ever chain saws are sold..
  • billtex wrote:
    Hockey pucks...
    ooooh... I like the simplicity of that reply... great idea!!!
    Thanks!!
  • Thanks John, I found the reference & pictures. Very interesting and easy way to accomplish the task.
    I appreciate your reference.
    Bob
  • Bob,
    Doug over on the Lance Owners forum http://www.lanceowners.org/ has made some for his Chevy and he likes how they work.
    On my to-do list.
    If you can't get to his post let me know, I'll forward his pictures to you.
    John
  • I don't have a Chevy, but I bought energy suspension bump stops. You should be able to do similarly.
