- naturistNomad IIdepends on the tow vehicle and the load and the road conditions and whether you are at altitude with a non-turbo motor and how fast you are going and whether the engine seems to be struggling and how hot the engine is getting and . . . .
- GordonThreeExplorer
DownTheAvenue wrote:
eubank wrote:
Read your owner's manual and follow what it says.
Lynn
X2
X3 ... for my vehicle, I do not turn off overdrive. town haul mode mostly takes care of that, and even in mountains areas i've never experienced so-called hunting - DownTheAvenueExplorer
Lynn
X2 - eubankExplorerRead your owner's manual and follow what it says.
Lynn - dtappy3353Explorertow-haul was designed for a reason.
- jmcgsdExplorerMy rigs are somewhat heavier than a PUP, but I would imagine that the same rules would apply.
If I'm in terrain where the O/D will be turning itself on and off frequently then I shut it off until I'm out of that area. That includes hills with varying grades, stretches of rolling hills and sometimes relatively flat areas where I'm driving into a strong headwind. If I'm on a long grade, the O/D has disengaged then I don't worry about it much. It will just engage again when I'm done with the grade. - Old-BiscuitExplorer IIIOnly if tranny starts hunting gears........
If it just downshifts due to grade and then upshifts afterwards no. - RoyBExplorer IIII do when I am in the hills but leave on on flat roads...
My POPUP weighs in at 4200lbs
I can tell pretty quick watching RPMs and switch it off... Mine will auto switch out when the drag hits a certain point and that scares the H@@@ out of you haha... It does that on cruis control as well... I'd rather turn it off myself...
Roy Ken
44,068 PostsLatest Activity: Apr 17, 2021
