So I went to my trailer today and put the front door key in the rear key lock but for the dead bolt. Then what's occurred is I cannot put the right key into the dead bolt key hole but it will fit into...
You probably have a known defective lock. There is a recall for the defective locks. As I recall the problem arises if you remove the key from the lock when it is in the 3 o'clock position. You must always return the key to the 12 o'clock position. There is a website where you can apply for a free replacement. Search this forum to find lots of posts on the issue.
