Be interesting to see how you guys like the Andersons...problem I see is that once you have the level spot, you need to lock in that position. The itty bitty parking brake on the Suburban is enough to hold the truck but not the truck and trailer, and not enough to hold the trailer at an exact spot on an arc like that long enough for me to get out put the chocks in.
Tiggs, what I would do is approach it in stages with the blocks. Put one block ahead of each wheel and drive up on them. The two block ahead of each wheel, etc. The tire won't go from zero to two blocks but if it goes from zero to one it should go from one to two OK. If you need 3 blocks, be sure to start at a point so you will wind up where you want the TT parked.
I have just enough room between the tires for 2 blocks side by side. I add a 3rd straddling the two if I need 2-high. If I need more I add on to the end of the set and go again.
