ruthiebaby88
Nov 28, 2014Explorer
Dually payload??
How do I figure a dually payload? I drove one and the sticker inside said the cargo rating is 2482#. Do you multiply x2 since it's a dually?
donn0128 wrote:bigcitypopo wrote:
Buy a wheelbarrow!!! My Ram 2500 CC short bed has a 2500lbs payload...
Honest numbers? Yea right. More like 1500 pound in real world payload. GVWR minus real world scaled weight is your honest payload, not some mystical numbers you read somewhere.
arto_wa wrote:bighatnohorse wrote:wintersun wrote:
. . . and the tires should handle at least 11,000 lbs. . .
This is a limited truth.
And I'm not sure about that!
It could apply when all four dually rear tires are on a level surface with weight evenly distributed on all four.
According to Michelin: Their LT235/85R16 LRE XPS Traction tires, when in dual configuration (or 4 tires per axle), the maximum axle loading is 11,112 lbs.
Wintersun is absolutely correct!
tonymull wrote:
No that trick doesn't work, and why would you do that when the payload (with factory equipment) is posted on the door where he is getting those two numbers???
