paulbeauchemin
Mar 15, 2018Explorer
parker.rowe wrote:
Aspect ratio? As in the "75" in that tire size?
That is pretty important. It IS the tire height.
245=tread width in mm
75=sidewall height as a % of tread width. ex: 245 x 0.75=183.75mm
17=rim diameter in inches
So...
total sidewall height in mm = 183.75*2=367.5
total sidewall height in inches = 367.5/25.4=14.47 inches
total diameter = 14.47+17 = 31.47 inches
Of course, there are discrepancies from tire to tire and manufacturer to manufacturer. But that is what the numbers are suppose to mean.
I see - if replacing just one of the tires in a dually that this would be critical
But if you replace all 4 is aspect ratio critical?
