egarant
Aug 16, 2021Nomad
Grit dog wrote:
eagarant, so you know the numbers, both weights and capacities. You said you refuse to do more suspension work ( as I read your post) yet you’re asking how to haul a 3+ ton TC on a 1 ton dually.
I’m not following.
Hauling one of them on a (new or newer) class 3 dually is akin to hauling a 4000+ Lb camper on a 3/4 ton. It’s done all day long by many people. Question is can you accept driving a truck at or near its practical limits?
Another consideration is the pickup bed itself. TCs are tough on truck beds and the beds are made the same so the heavier you go, the more considerations or damage you may expect (vs a flatbed).
This appears to be a rhetorical question that you already have strong opinions about or against, so why the question?
I'm against doing nickel and dime suspension add on's, I don't believe adding a sumo spring, air bags or Torklift stable loads are the proper or safe way to increase a trucks capability.
I currently drive my TC at it's practical limit, 600 lbs over my GVWR.
I've never experienced any TC I've owned damage any truck bed so I don't follow, it they are mounted correctly the truck bed should be fine.
My question was and still is....is anyone actually carrying a EC 1200 triple on a F350 dually.
