shastagary wrote:
this is what it says on the amazon page of that inverter that i also own. it can easily draw more than 10 amps with the heater load
If the rated input of any connected AC devices exceed 150W, please use battery clamps to directly connect to your vehicle's battery as most vehicles' 12V cigarette lighter ports are rated for 150W. Do not use to power high power electric devices such as hair dryers, electric heaters, which might blow a fuse.
:o guess we will count ourselves lucky with a couple blown fuses.
I better relook at the DVD and TV wattage. Thanks for pointing this out.
