icanon wrote:
DutchmenSport wrote:
Good question, good way of thinking, but I think you be voiding your warranty, and running the risk is introducing bigger problems in the future. I "think" it's best to stick with he manufacture's method ... dicor.
I understand about the warranty but some manufacturers warranty is only 90 days to 6 months then what? I'm not conflicting with you but after the warranty it's up to the owner to decide how and what to do with maintenance.
Is Eternabond a better method? I don't know, is Eternabond life span worth it? Is Eternabond once weathered, worn or damaged is it easy to remove, replace or repair? Does Eternabond preforms well under hot to freezing temperatures to driving couple thousands miles per year with all vibrations twisting etc. I too, have questions on Eternabond and very interested in this product but still weighting on whether I should use it or not. Hopefully some can provide some insight on this product.
Thanks
There have been postings on the Forum where it is
rumored that a salesman told a customer his warranty on the roof was voided by the use of Eternabond tape. It was not stated whether the owner was trying to enforce a warranty, needed to do so, or that what was communicated was fact or fiction. I file it under unproved Internet myth and not applicable. The use of Eternabond would make the point moot, regardless. If an owner installs it, he won't have a roof issue.
My story: I rebuilt my trailer, totally gutted it. In the repair process, the top wall framing plates were removed and replaced. The roof trim edge was removed and wall siding/roof membrane was loosened to facilitate the repairs.
When reinstalling all the pieces, a bead of elastomeric urethane caulk was placed between all the pieces removed or loosened--framing to siding, roof to framing, siding to trim edge, trim edge to roof. The first rain, I noticed a couple of very small leaks.
To stop the leaks I placed Eternabond tape on all of the roof joints and over the top of the aluminum trim edge. At this time I also sealed all siding joints with Proflex caulk.
I then performed the first of a few pressurized leak tests. The first test showed about 20 leak areas, all of them near windows, through screw holes, or other gaps in the siding.
No leaks were found in those areas where Eternabond tape was used. I perform the leak test almost annually and have had no leak problems since. I now believe that Eternabond tapes are superior to any caulk or sealant used.
If I was the OP, I'd clean up the roof joints and apply the tapes. He should have no more sealing maintenance for the life of his trailer.
