Thunderbolt
Aug 06, 2014Explorer
You are close, but the 2500HD does not have an actual body lift. The frame on the 2500HD is totaly different than the standard 2500 or 1500HD. The frame is taller on the rear section and it is a slightly thicker steel.
Dannyabear1 wrote:fireman41 wrote:
It a non hd 3/4 TON. It has 8 bolt wheels.
It the same truck as a 2500 not to be confused with the 2500 hd.
This is correct///////
I have a 2002 1500 HD which is a 25oo non hd markings, they only come crew cab, 6 1/2' bed, 6.0 engine, 4l80e transmission, and 3;73 or 4;10 rear end
The 2500 hd of the same years was only available with 8' bed and had the body lift kit;
They are great towing vehicles but don't get much MPG and need an acre to turn the around.
44,066 PostsLatest Activity: Oct 04, 2013
