recycler
Aug 25, 2013Explorer
the camper manufacters have equipment to bend it..your right it will kink some when it is bent tight..the way i deal with that is to bend it then use rubber mallet and block of wood to shrink the sides in..you could use the same trick to repair the orginal peices too
44,066 PostsLatest Activity: May 15, 2026
