superlaxman's avatar
superlaxman
exterior light
I have replaced bulb and checked fuses but my exterior light won't come on. 2013 Blackstone. Help please
  • Usually a bad ground or bad connections at the light or switch.
    If rodents have gotten in may have chewed wires some where along the line.
  • We have a WindRiver and you will probably need to use the remote that operates the slides and stabilizers, there is a place to turn on the outside light there. We need to tell it it is OK after we operate the battery disconnect switch. Then the rocker switch will do the off on function OK. JMHO
