Maury82's avatar
Maury82
F-150 HDPP towing 37 ft TT ** 1,300 miles later**
2018 F150 3.5 EB, 4x4,XLT, S.Crew, 6.5ft bed, HDPP.
Payload: 2,470lbs, 1,320lbs hitch ratings.
Towing ratings:11,500lbs.
Trailer: 37ft, 8,400lbs dry/9,900lbs max, 1075lbs tongue.
The trailer had a half full freshwater tank and most of the items that I plan to leave in it permanently. The heaviest single item I might add to the truck is a girlfriend, and she is pretty fit. I would anticipate an extra 500lbs added pounds to both truck and trailer max.
I got the B.O. hitch setup, with the truck squatting 2" in the rear and raised 1/2" higher up front, so the truck actually sits level hooked up.
The weather conditions were dry with a 10-15 mph breeze.
Got up on I-70 eastbound and merged without effort, and before I knew it, I was flowing with traffic at 70 mph (Goodyear Endurance trailer tires). The trailer did not get pushed out or sucked in by passing cars or big rigs, not even when a tandem truck came barreling past me.
I prefer to drive 65 mph, because when I drove 70 mph, big rigs seemed hesitant to pass, but passed more often at 65 mph.
As the trucks passed, I was bracing for that pull/push that so many keep proclaiming I will suffer.
I did feel the trailer back there, but it was just more bouncing when hitting the overpass joints versus when not towing, and the rear wasn't as stiff-legged, and had more up and down movement versus when empty. I hear that Bilstein improve both town and non towing ride...next year project.
The steering wheel felt a bit lighter than not towing, but it was still accurate and didn't need anymore corrections than not towing.
I drove 75 mph just to see how the trailer would respond, and I did feel more movement back there, but never anything that made me feel swaying was occurring, and probably just me not used to how the trailer feels while towing.
I drove for several hours on both I-75 and I-70, with some time spent in the middle lane so I can feel traffic on both sides, and everything felt stable without any wandering from side to side.
When traffic suddenly slowed, the setup slowed pretty well, and I didn't feel pushed, but that the trailer was holding up its end regarding to braking, and I tested that quite a few more times.
After a while,the nervous anticipation of being passed by big rigs faded away, and I came away feeling pretty confident. I even forgot it was breezy out...lol.
  • Good report and not surprised with your excellent results.
    Also not surprising was all the Monday morning quarterbacks who advised against your truck setup.
  • Groover wrote:
    So you are saying that hitched up the truck is 1/2" lower in the front? I used to do that because I think that it drives better but I think that you should be aware Ford does not recommend that. They actually want the front end higher than empty according to page 36 of the towing guide: https://www.fleet.ford.com/resources/ford/general/pdf/towingguides/Ford_Linc_18RV&TTowGuide_r8_May15.pdf
    The only reason that I can think of for this is that they don't use a frame mounted hitch on the F150, just a glorified bumper hitch. They might be afraid that enough torque to pull the front end down will rip the bumper off. I admit that this is speculation on my part and would love for a Ford engineer to explain their reasoning but it hasn't happened yet.
    1/2 higher up front after a got the trailer setup with hitch.
    I actually did said lower initially...I'll edit that.
    It was 2 inches lower in back.
  • So you are saying that hitched up the truck is 1/2" lower in the front? I used to do that because I think that it drives better but I think that you should be aware Ford does not recommend that. They actually want the front end higher than empty according to page 36 of the towing guide: https://www.fleet.ford.com/resources/ford/general/pdf/towingguides/Ford_Linc_18RV&TTowGuide_r8_May15.pdf
  • theoldwizard1 wrote:
    Maury82 wrote:
    I got the B.O. hitch setup, with the truck squatting 2" in the rear and 1/2" up front, so the truck actually sits level hooked up.
    So it is squatting without the trailer ?????
    I would hope not.
    I set the hitch up with a trailer attached, and then you try to restore the weight or height back to the front axle that was lost when you dropped the trailer coupling on the truck hitch.
    The front was 1/2 inch higher, and the back was 2 inches lower after I got the Blue Ox tension bars adjusted with the trailer hooked up.
    The truck is normally jacked up higher in the rear than the front, so after everything got set up, the back and front looks even.
    Trailer: 37ft, 8,400lbs dry/9,900lbs max, 1075lbs hitch. The trailer had a half full freshwater tank and most of the items that I plan to leave in it permanently. The most single item I might add to the truck is a girlfriend, and she is pretty fit. I would anticipate an extra 500lbs added pounds to both truck and trailer max.
    I got the B.O. hitch setup, with the truck squatting 2" in the rear and raised 1/2" up front, so the truck actually sits level hooked up.
    As the trucks passed, I was bracing for that pull/push that so many keep proclaiming I will suffer. I felt a little tug and push, but I also feel the same sensation when driving a car or when not towing. I was holding on the wheel waiting for this big event, but nothing dramatic happened...more buffering than anything else.
  • Groover wrote:
    It sounds like you are very happy with the setup. What was your fuel economy with the trailer?
    I didn't reset it for the trip, but when not towing, I average 19.5 mpg on the freeway at 77mph on an 1,800 miles trip, with a heavy foot while passing.
    I was pretty pleased with how it worked out . I read how the HDPP trucks tows its rating well, and this truck didn't disappoint.
    I believe those Goodyear Endurance played a part in the trailer not moving around, because when the installer and I were comparing them side by side, the GY's sidewalls were more than twice as stiff than those China bombs. I could actually compress the China bombs a little with one hand, but couldn't budge the GY.
    The China bombs had some extremely soft sidewalls, and it was such a shock to me, and I'm relieved I took them off.
    The GY were heavier also.
  • It sounds like you are very happy with the setup. What was your fuel economy with the trailer?
