AlmostAnOldGuy
Jul 19, 2016Explorer
brulaz wrote:AlmostAnOldGuy wrote:
With truck in signature towing 28' at 8k loaded. Well within specs including receiver which is rated at 1500 <-- should read 1150.
Note this is Max Payload (LT tires, stiffer suspension, heavier axles). If you are towing relatively heavy I recommend LT tires and ensuring you are well within your payload and axle ratings per yellow sticker.
Good luck,
Stu
Is that an after-market hitch receiver?
And which one?
AFAIK the OEMs were only 1150# with WDH on the MaxTows until 2015 when they went up to 1220# (IIRC).
You are absolutely right. That is a typo - my hitch is 1150. Just went and fixed my post.
Thanks,
St
44,071 PostsLatest Activity: Aug 30, 2026
