Crowe
Jul 06, 2016Explorer
F150 brake issues continue-AND THE WINNER IS...
It's been a while since I posted but we continue to have brake issues with our 2012 F150. At low mileage the front rotors needed to be replaced. We've had continual problems with the brakes not pressurizing correctly on start-up of the vehicle-brake pedal goes right to the floor until it's pumped a few times. We had the vacuum pump recall done which alleviated the strange noise we were getting but the brakes continue to have the same issue. When the truck is not running the brake pedal doesn't budge at all. My experience on previously owned F150s is there's at least a little bit of play when you depress the pedal upon starting the engine. Thoughts? It's going back in the shop next week and any suggestions on what direction in which to guide Ford would be helpful as the service advisor seems a bit clueless. Thanks.
