Ncm86
Apr 24, 2014Explorer
f150 payloads
Ok, im confused trying to find a good TV for the family, i thought as you drop in models on the F150 line, the payload would mostly likely increase due to less packages add to the truck. from what i h...
mosseater wrote:
Mine's 2200 lbs with XLT and nicely optioned. Get the HD payload option with the other goodies and you'll get a number somewhere north of 2000 lb in most cases. Put's your GVWR at 8200 lbs. Two wheel drive, regular cab I believe goes to 3000 lbs or so. I think Skip's old 150 was 3000 lbs.
