Me Again wrote:
What is the GAWR for the rear axle of the truck? That is the first place most get in trouble with. Disregarding that, the dry pin weight of the trailer is fairly low. I think it will be fine if the truck has a 7K RGAWR. Does not sound like you will be installing a W/D in a front closet and generator, two things that both add to pin weight.
I will be ordering it so I’d assume I can pick from the options below. I will be sure I choose the highest. If that isn’t available with the combo of other options I want, I’ll have to rethink things.
