4x4ord wrote:
I can’t imagine why anyone would buy an F350 with a gas engine .... my way of thinking is if I need more than a half ton to pull it I’m going diesel, but, yes a F350 SRW 7.3 gas would work for that trailer. You’ll want the 7230 lb rear axle.
I’ll ask a leading question, like you tend to do a lot.
What is different about the “7230 lb” rated axle from the other F350 axles? And what would make the lower rated ones or even the smaller axle in the F250s unsuitable for an up to 9000lb + rear axle load?
