720Deere wrote:
OpenRangePullen_Ford wrote:
A 3.31 doesn't belong in a truck, its useless. Get the 3.55 or bigger for sure, It will give you more useful power.
That's funny because not that long ago people like you said that 3.55 was no good in a truck and not long before that they were picking on 3.73. When diesel motors had 200 hp and less than 400 lb/ft, gearing made a bigger difference than it does now at 400/800 and beyond.
I have 3.55 with the 20" wheel option and towing 16,000 lbs is no problem at all. I have no problem maintaining greater than 62 mph in the mountains which is extraordinary compared to trucks just a few years ago. I was initially leery of 3.31 when they were first offered, but after 3.5 years of experience with the 3.55, I would not hesitate to get 3.31 with 18" wheels. If you intend to install larger tires at some point, I would stay with the 3.55, but 3.31 with stock 18" tires is going to net you the best fuel mileage and will still perform the same as a 3.55 truck with 20" wheels.
It depends, do the new Fords have the four speed with overdrive or are they still three speeds.
