720Deere wrote:
Lynnmor wrote:
I believe that you will find the 20" tires handle less load than the 18"
Can you expand on this theory? My 20" tires as well as every other 275/65/20 tire I have ever seen are rated at 3750 lbs. 18" tires typically max out at 3640. I will also add that with 20" tires the RAWR is 7,000 lbs on an F350. I don't recall seeing a truck with 18" wheels rated that high.
Yes, I see that you are correct after comparing the two. When I ordered my truck 3 years ago, I was given a lower rating for the 20".
