- PopparexExplorerI have a 2019 f350 dually and it dents when you look at it too hard. Other than that i have no complaints so far. Have only 5K miles on it so far. i was told (but the specs above may dispute it...) that they took the weight savings and beefed up the transmission and other areas...?
- burningmanExplorer II90 pounds lighter is closer to the truth.
- Ski_Pro_3Explorer06 Dodge Ram 3500 with an 8' bed that had been sprayed with Line-X ~1/8-3/16" thick. 412.26 pounds
- Grit_dogNavigator II
Kayteg1 wrote:
Just put over 8000 miles this summer for total about 30k.
Aluminium bed shaves about 900 lb from the rear, so my 6000 lb camper goes without any modifications.
I only add Sulastic hangers for empty ride comfort.
That's a phenomenal weight reduction for the aluminum bed!
Considering a normal steel 8' bed weighs maybe 400lbs, maybe 500lbs tops with dually fenders, having a truck bed that weighs negative 400lbs is awesome! - Kayteg1Explorer IIF350 like in my footnote.
Google Sulastic hangers. It is the best $300 I spend on the truck. - dennych1ExplorerDo you have a f350. Also what is sulastic hangers never heard of that
- Kayteg1Explorer IIJust put over 8000 miles this summer for total about 30k.
