klr650goldwing's avatar
Feb 20, 2020
Ford Puck System
We recently bought a 2017 F350 Lariat CC DRW 6.7 LB 4X4 and now we need to put a hitch in it. How do I tell for sure whether or not this truck has the PUCK system for the hitch mount? It does have the four small pockets in the bed. But someone told us that the main part of the puck system is under the bed. Can anyone explain what we need to look for to tell for sure whether we have it or not?
  • Since you sent me a PM on the subject and now are asking some of the same questions I will just post my reply to you as it's no secret.
    That's great! You do have the puck system. You also have a LongBed, that's great also!
    There are two B&W hitches for your puck system, BWRVK3300 is 20k rated @ $1,044 and the BWRVK3305 is 25k rated @ $1,262 at Trailer.com.
    So it depends on the LOADED weight of your RV what one to buy. Personally I would go with the 25k as it will cover any 5er you can haul with your truck.
    "ford truck guy" that posts on here recently ordered a 2020 F350 LB SRW and also ordered a 20k B&W since his RV won't weigh over that much.
    Since you don't need a slider there is no reason to discuss PulRite.
    B&W is the most simple hitch to hitch and is a no question if you are hitched setup. The 1" thick machined jaws hold the kingpin tight with ZERO rattling about like many other hitches.
    The pivot points on the head are right at the same elevation as the kingpin connection so you will not have chucking associated with the hitch like Curt Customers have reported.
    B&W is simply the best non air ride hitch on the market! One good reason is they are easy to hitch and unhitch when the truck and RV are on different planes. Curt for example can be VERY frustrating to use in those conditions.
    I have owned other brands but B&W puts them all to shame!
    Another bonus IMHO is the fact B&W hitches and products are all Made in USA.
    Any other questions I can answer let me know!
  • Pull one of the plastic plugs and you should see a rectangular slot in a steel bracket. Its sort of like a skeleton key hole. The corresponding rotating “pins” which are on the four corner arms of the picture frame drop in those holes and rotate 90 degrees so that they cant lift out of the hole. If it has the plastic caps id think it has to have the keyhole brackets. My plastic caps are rectangular on the underside and shove down into the keyhole If you look under the bed you should see the brackets in the area of the plugs in the bed.
  • It should have four pockets arranged in a rectangle, with a larger hole in the center (for a gooseneck). They may have plastic covers over them. These will be more or less centered over the rear axle. You should have a 7 way plug in the side of the bed near the tail gate for the fiver cable to connect to.
    I can't think of reason to have those holes unless you are set up for the puck system.
  • Simple. You will see 5 holes with plastic covers. The 4 corner holes are used for mounting a fifth wheel hitch. The center hole is for a goose neck ball. If you don't have the holes you don't have the puck system. If you do the bracings are all underneath the bed. All you will see in the bed is the holes.
