Redneck_bling
Sep 10, 2018Explorer
This is coming a little late for you. I had my 1999 f-250 rot out real bad. The cross frame supports under the truck bed completely dissolved into a flaky croissant. I sold it and cried the blues loosing my 7.3 diesel! I bought a 2016 f250 with a 6.2 and here is my point: I now put the truck up on a lift and spray the underside, cable's, leaf springs, everything, with amsoil metal protector. A case sets me back about 150 bucks. Compared to 46 thou for a new truck, its a no brainer. I have made flexible spray can nozzles that are 2 feet long tubes that allow me to insert into the cross rails, frame, pillars, etc. I spray the **** out of the underside. This is the only way to get 20-30 years out of a truck, with out it turning into a rust bucket. I'm offering this as a solution to everyone to prolong your trucks life. I learned the hard way. I'm fortunate to have access to a lift. Perhaps talk to a local garage about after hours use of their lift. Bring lots of cardboard to put down under the lift to catch the drips. Most shops wont like the residue. Also...for gods sakes...wear a proper fitting respirator. Although there is minimal solvent, you don't want to inhale a sealant. At 1st appearance it looks watery, but it dries to a hard wax like coating that is semi translucent.
I run on salty roads in N.J. and drive on the beach. I had to do something to repel the salt effects.
I recommend you power wash underside, and let it completely dry before proceeding.
Oh... i dont sell amsoil. I just think I like their stuff better than fluid film, and spraying undercoating like rustoleum? That just masks and covers rust. The MP is translucent and can be recoated as needed. Its also flexible so i don't flake. When your done...your truck will smell like a crayola crayon for a while. The smell dissipates quickly though. Also clean off any overspray before it hardens. Once hard, its a pita to remove.
44,066 PostsLatest Activity: May 15, 2026
