1handyhubby's avatar
1handyhubby
Ford transmission question.
I think I should have my transmission checked out but thought I'd check here and on the Ford forum. My 2001 F250 5.4 3.73 rear shifted really smooth. I loved driving that truck. The new 2001 F350 6.8 4.30 rear shifts a little lets say clunky? A little jerk to it? My brother in law who has owned several duallies says it's fine. To me it seems a little rough because I've never driven anything that didn't shift smooth. Any thoughts?
  • Bigger engine, stiffer springs and a lower geared rear end, it won't feel the same when it shifts. Does it shutter, or have a delay when you move the shift lever?
  • Sorry, I should have added more information. The truck only has 49,000 miles on it. I'm the third owner. The previous owner hasn't had any issues with it and used the truck to tow his toy hauler to the desert and didn't drive it daily. He said it has always shifted like that with no issues. It could be normal I just was curious if others had theirs shift this way. Thanks.
  • Is it tuned? Did the PO have it rebuilt? If so, the tune and rebuild could lead to a more harsh shift. Not a bad thing at all, you want a positive shift and not a slippery, sloppy shift as that means it is building heat and heat kills auto's.
    Or your trans is dying. How many miles?
    Your truck is 15 years old and used. Hard to guess without more info and background. If it doesn't feel right have it checked out.
