- carringbExplorer
colliehauler wrote:
carringb wrote:
Just curious if it is possible to change the 2 valve motor out for the 3 valve?
All Excursions use the 2-valve design. Even the 2005 which is the first year of the 3v in the pickups.
Don't plan on doing it, just wondered if the electronics would match up.
I'm pretty sure you have to swap harnesses because the 3-valve has more sensors.
But.... 2005 also brought in CAN-BUS communications in the F (and E-series) gas motors. I'm not sure if the Excursion also got that electronics update. Swapping to CAN-BUS would also mean all new modules (Air-bag, PCM, ABS etc) so I'm not even sure its possible. I'm a little suspicious that maybe the Ex didn't get the 3-valve because it didn't get the CAN-BUS upgrade. It's probably way easier just to add a Supercharger! Or even the Banks PowerPack. The 2-valve with PowerPack pretty much matches the 3-valve output. - colliehaulerExplorer III
Don't plan on doing it, just wondered if the electronics would match up. - colliehaulerExplorer IIIWent with APP 103 plugs. New plug's coil's and labor was $433. I did not think that was to bad.
- MegaCab_PLExplorerOk, so there was never 3v Excursion ? Interesting. I see 3v 6.8 F250's
- carringbExplorerAll Excursions use the 2-valve design. Even the 2005 which is the first year of the 3v in the pickups.
- MegaCab_PLExplorerI do not even see what year 6.8 the OP is asking about .....
Did I miss that ?
Different issues based on the year. I have an 06 Explorer with 3v 4.6 and had to deal with the 2 piece design. - bid_timeNavigator
dodge guy wrote:
Exactly, One screw and a quick connect; and they sit on top of the engine. I can change any coil on my V10 in a matter of minutes. No. 5 might take twice as long because you have to move some hoses and tubes. No. 6, & 7 you have to take the air cleaner tube off first.Home Skillet wrote:
$500 is cheap insurance, when you're 800 miles from home.
I was a Ford tech for 25 years. The last place I would want to do coils is ,on the side of the road.
:h They are easy. I can replace one in a couple minutes. even the far back ones!
More importantly, I have never had one just plain stop working. They start to misfire first. They will do that for 8 or 9 days at least (which is how long I have waited before to change one - not recommended however), and probably longer. Which gives you plenty of time to change one when it is convenient to do so. - dodge_guyExplorer II
:h They are easy. I can replace one in a couple minutes. even the far back ones! - Home_SkilletExplorer II$500 is cheap insurance, when you're 800 miles from home.
I was a Ford tech for 25 years. The last place I would want to do coils is ,on the side of the road. - dodge_guyExplorer IIOn the coils. Just do what I do. I carry to extras with me. I won't install any new coils until they fail just because of the price alone. $500-$600 for 10! More or less depending on where you get them.
