rockhillmanor
Apr 04, 2017Explorer II
That blade is very narrow and if something like TP paper is stuck in the track it will be hard to push in or out.
You need to drain tanks and then open the blade and run a brush around the opening.
that or sometimes I just spray silicone spray on the rod and that helps but ultimately you will need to replace it if its worn.
44,068 PostsLatest Activity: Jun 09, 2026
