Dtaylor wrote:
The following is from the etrailer website:
On the Draw-Tite Friction Sway Control, the handle is an on and off device. The bolt that is located below the handle is for tension adjustment only.
To adjust the tension on the sway control assembly, a series of road tests should be taken with the loaded trailer. Increase or decrease tension by turning the adjusting bolt in 1/4 turn increments in the direction shown on the label until the desired control is achieved.
Correct answer! :) If you use top, long handle for adjustment, you will never know exactly how much tension you are putting on the bar. It is for on/off use only.
Barney
