AnEv942
Sep 02, 2020Nomad
By description failure point?
"So what always breaks is the top of the triangle here in the pic. Where the support bar meets the upper mounting plate. The very top of this pic. In my old set the welds gave out between the support bar and the main structural member."
I'm having a hard time understanding how camper (without ripping its mounts) is applying enough force? it would almost seem that downward force, possibly side to side, would need to be applied for that upper weld to fail. Have you contacted Torklift?
NRALIFR-Curious, though doesn't look like with new upper tie off point would give enough angle (and you've solved your problem) why is the lower mount not to the hole in end of insert plate?
44,071 PostsLatest Activity: Aug 30, 2026
Related Content
- Feb 01, 2026Community Alumni
