AnEv942
Sep 04, 2020Nomad
The style of TL mount is different than shown earlier, and a lot different than mine.
OPs are not welded at top to a piece of angle but end is bent and bolts to bed cross member. Shown in previous thread.
IF the bolt drops, upward force from camper the flat bar brace can 'slide' inboard, that in turn breaks lower weld.
2 issues-1st This style works in conjunction with frame tower and existing bolt plate, Ops towers are shredded.
Second and primary is instead of a 1/2" bolt going thru mount into bed someone dropped a smaller bolt thru.
While there is a lot of torn metal it sure looks like someone cut out the top of towers?
Mount brace is supposed to mount to it. Issue here is from what I gather, the bolt that's supposed to go up thru is also the bed mount...
If OP can fab a belly bar should hold camper, really doesn't take that much.
The existing situation/condition & way it was bolted, only option was to fail. Still need to address bed mount towers, if that is what it also does.
Related Content
- Feb 01, 2026Community Alumni
