carl2591 wrote:
SO when looking at a transfer tank for diesel fuel knowing the alum tanks are quite a bit more expensive, what is the average life of a tank that uses diesel vs gas and steel vs alum.?
I was looking at the http://www.tractorsupply.com/tsc/product/delta-steel-transfer-tank-37-gal?cm_vc=-10005
this one a steel 37 gallon tank for 300 bucks.. I was going to pipe into the fill tube with bulkhead fitting and elec solenoid valve that is normally closed.
the plan was to fill both frame tank and bed tank and when frame tank get to below 1/2 open the valve to allow fuel to flow into tank.
I did read one place someone get a Check Engine light come on doing that.. it was something to do with fueling while running? this was on a ford SD I think older pre 2000 year.
thanks
Yes, you would get a check engine light. It's the same code you would get for accidentally leaving your gas cap off. Your vehicle must check your fuel system for integrity to ensure no fuel vapors are leaking into the air. Most do this by pressurizing the tank with a pump. If your tank cannot hold pressure, it will throw a code. So if you initiate a fuel transfer while the tank is pressurized (vehicle running), you've just compromised the integrity of the main fuel tank.
This is not an issue on diesels since diesel fuel is not as volatile.
As far as I know, having a check engine light due to the above on will not cause issues with your vehicle's performance. If your local jurisdiction requires emission testing, it might be a problem. Otherwise, you could just live with it. Personally, I'd just get a tank with the fueling nozzle and fill it at a rest stop instead. Usually somebody needs a pit stop well before the tank is empty anyway.
