RCMAN46 wrote:
GeoBoy wrote:
On the transfer case you should overfill it by 1 quart. The way to do that is by removing the switch on the top of the case towards the rear of the case and adding the additional oil there.
What is the purpose of overfilling by 1 qt?
My understanding is that the transfer case used in his truck would run hot and literally cook the lube to a vapor. They actually said to change to 5W-30 oil but I ran the Torque-Drive synthetic fluid recommended for Allison transmissions and added the extra quart. Never had a leak from the overfill. My transfer case was a manual shift case.
