I'd like to know whether a higher or lower gear ratio is better for towing. Considering a 2013 or 14 Silverado 2500 4wd. I plan to be in mountains as well as flats. Don't know what I'm going to tow...
Get the lowest ratio available (highest numerical). Although it is not as critical with the newer 6 speed transmissions. 4wd is double the cost to swap gears if disappointed with oem. You will not lose much if any fuel mileage for the lower gear and may even improve towing efficiency.
