The truck is a 1988 R30 Silverado dually four door weighing in at over 6600 lbs. The horsepower will be 375 hp, 400 lbs. torque with a Turbo 400 3 speed. Towing a 30 ft Airstream at 7800 lbs. Would li...
375 hp, 400 torque tells me its a small block? That's pretty hot for an '88, more hp and torque than a new one. I wouldn't change the rear axle gearing, I'd add an overdrive either by going to a 700R4 built for towing or an add-on overdrive like a Gear Vendors.
What kind of engine mods do you have to make that much power?
