tinkerman56ExplorerApr 18, 2018gear ratiosThe truck is a 1988 R30 Silverado dually four door weighing in at over 6600 lbs. The horsepower will be 375 hp, 400 lbs. torque with a Turbo 400 3 speed. Towing a 30 ft Airstream at 7800 lbs. Would li...Show More
time2rollNomadApr 18, 2018Have you driven it yet? What rpm are you running on the flats? How well does it hold speed going up 6% grade or into the wind?I would aim for about 2500 rpm running a flat road. But depends on how the torque feels. You don't want to be downshifting too much.
Related ContentRear gear ratioTowing with 6.2l 3.23 gear ratiorear axle gear ratioGear Ratiogear ratio
