The truck is a 1988 R30 Silverado dually four door weighing in at over 6600 lbs. The horsepower will be 375 hp, 400 lbs. torque with a Turbo 400 3 speed. Towing a 30 ft Airstream at 7800 lbs. Would li...
There is not much other than a new motor will get you beyond maybe 9MPG. Those old school big blocks were simply gas hogs. You do realize that all the work your doing to the motor can only make matters worse. To get HP you need fuel. You might be better switching the old inefficient carbuetor for electronic fuel injection.
