tinkerman56ExplorerApr 18, 2018gear ratiosThe truck is a 1988 R30 Silverado dually four door weighing in at over 6600 lbs. The horsepower will be 375 hp, 400 lbs. torque with a Turbo 400 3 speed. Towing a 30 ft Airstream at 7800 lbs. Would li...Show More
tinkerman56ExplorerApr 18, 2018yeah the rear end will be the last project just to see how the 410 will work. Basically putting a 1974 chevelle in a 6600 lb crew cab
Related ContentRear gear ratioTowing with 6.2l 3.23 gear ratiorear axle gear ratioGear Ratiogear ratio
