6pac's avatar
6pac
Going solar
Am considering installing two extra batterys an a 100 watt solar panel a top our Lance 881 . What type of controller an monitor would be needed? Any suggestations on the size an make of the inverter needed to power a microwave, TV , hot plate & diretv dvd? All suggestions would be appreciated.
After reading the responses of most we have discovered that it's not only possible but many have showed us how they've done their mods! Most use the ref vent to gain access to the inside of the cabin . Our Lance 881 doesn't have a ref vent, our ref is located on our slideout. We have a 55 watt located on the forward part of the roof , considering a 100 watt to be located toward the rear of the passanger side. To be mounted on the unistrut attached directly to the Maggie rack which will place the panel very close to the roof.( 11/2" above the surface. Also to readdress the location of the new two batteries ...they will be located on the driver side opposite the generator with wiring running across to the generator thus connecting all batteries together. The major problem we've found is how to gain access to the cabin. We're working on it!
  • RoyB's avatar
    RoyB
    Explorer III
    To be successful camping off the power grid First you need to reduce your 12VDC power drain everywhere you can. Changing over the ceiling lights to LEDs is a hugh big step here...
    Then you need to beef up your trailer with more batteries to run all of the things you want to run running directly from the 12VDC Batteries or from an proper sized INVERTER connected to the battery.
    Then you need to come up a successful way to re-charge your battery bank in a quick manner. Changing over to the smart mode charging is the way most folks go. Then you need to learn how to quickly re-charge your battery bank in a quick three hour run time which usually is best to connect your trailer shore power power cable directly to a 2KW generator 120VAC receptacle. Solar Panel will only enhance the charging of your batteries unless you have many many panels. A 120WATT Solar panel will only produce around 5 AMPs of DC current. To re-charge just ONE DEEP CYCLE battery in a quick three hour run time you will need around 14.4VDC at between 17-20AMP DC Current to do this.
    You just can't run into the woods with a small solar panel and do much of anything. You will get behind in your battery charge status real quick and if it stays this way for any long period of time it will harm your batteries.
    Rule of thumb for long battery life is to always re-charge your deep cycle back up to their 90% charge state when they get drained down to around 50% charge state. Letting them set in a discharged state is very harmful to the life of your deep cycle batteries.
    Three 120WATT Solar Panel will give you around 15 AMPS of DC current but only when you are in HIGH SUN. Can't depend on having high SUN when you really need it. Might be a cloudy day. Might be cloudy for a week... This is why you must have the Generator as primary method of charging your batteries. Then the small solar panels can supplement the generator run time and maybe not have to run as much.
    Also you have to follow the camp ground generator run time restrictions that may be in place. This is why you want to get re-charged in the three hour generator run time period.
    Of course if you just want to be in the woods and run a light for a couple of hours maybe fire up the TV etc then a couple of batteries will work for you. When they get run down however you really need to re-charge time in a timely manner otherwise you batteries will start going bad on you... I give up candles and a bag full of D-CELLS batteries along time ago.
    We are just now considering to add SOLAR PANELS to our 255AH Battery Bank setup. We do just about everything we do at an electric site except no air conditioning and can make it through the one day/night run off of the batteries and be right at 50% charge state the next morning. This is when we re-charge the battery bank using smart mode charging techniques being run by the 2KW Generator for three hours. Adding SOLAR PANELS will hopefully reduce the times we need to run the generator. We cannot be successful unless we start each day/night run off the batteries with them charged up at their 90% charge state. NO fun running out of batteries at 10PM at night on the East side of the US.
    Lots of things to consider here to be SUCCESSFUL. NOTE I mentioned the word SUCCESSFUL...
    It will take some planning and trial runs on what you really want to do when camping off the power grid...
    Roy Ken
    I would advise against installing batteries on top...too much weight up high! ;)
  • Pretty much need 2000 sine wave watts and four batteries to run the microwave. Probably more solar too.
    300w will run the tv, satellite, dvd, laptop and charge small items. With <300w you can use existing battery connections and not pull wire. I recommend Go Power brand sine wave inverters.
  • donn0128 wrote:
    Forget trying to power a microwave or anything else that consumes lots of power. Just not practical. A 500 watt inverter will run the TV for several hours.
    Power a microwave or other devices that consume "lots of power" is practical and can be done, so long as it's items that are used in shorts durations, like a microwave, hair dryer, coffee maker, etc. An air conditioner, NO.
    I run a microwave with an inverter.
    Any size inverter over 150 watts will run a TV. It's not the size of the inverter that dictates how long you can run a TV (as some people may think by reading a previous message) it's the size of the battery bank.
    If you have at least 200 amp hours of battery capacity, there's no problem running a microwave. I do it every time I go places. Generally it's only a once a day thing.
    To run a microwave, you will need a pretty large inverter - 1500 watts or more.
    AM Solar is one option: Their website http://amsolar.com/
    Read Sleepy's thread here: http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/27916220.cfm
    He uses an inverter to power a convection oven.
  • Hi,
    If you go for a pair of 12 volt AGM batteries then running the microwave for short periods of time becomes possible. You would need a 2000 watt inverter.
    I would suggest at least 60 watts of solar for every 100 amp-hours of storage.
  • Forget trying to power a microwave or anything else that consumes lots of power. Just not practical. A 500 watt inverter will run the TV for several hours.
