donn0128
Apr 29, 2016Explorer II
Its not uncommon for new tires to behave badly when new. But....
You have the rear tires aired to 85PSI? Is that not already 5PSI over the max posted on the tires sidewalls?
You have mixed tire types on the truck?
You put the new tires on the rear?
I think you need to drive across a set of scales to see what your weights truely are.
Put the new tires on the front, unless this is a dually.
Unless its a dually and even then it is likely your exceeding the RAWR, and also the trucks GVWR.
