Glennsgarage's avatar
Glennsgarage
Got new rear tires and now my truck sways on the highway
i have a 2400lb Bigfoot on the bed of a dodge 3500 and weigh in at 12000 lbs total.
I had 4 bfg all terrain at tires load range E, sway bar and air bags and it was very stable.
I blew out a rear tire and replaced both rear tires with the new bfg ko2.
Now my truck sways a lot on the highway. Almost felt like before I had a rear sway bar. Rear tires are aired up to the max 85lbs.
Front tires are not the ko2 and have 25000 miles on them and 65lbs pressure.
What do I need to do to have a stable highway ride again?
Thanks!
  • I switched from P rated tires to E rated BFG LT's and for the first 100 miles thought they were terrible. They seemed to settle in and am very happy with them now.
  • I'd check the air bag pressure and probably reduce each of them to 20-40 lbs. My guess is the tire dealer "helped" you and added a lot of air to the air bags.
    The other thing to check is whether the new tires have the same load rating that the previous tires did. Range E is a range and the tire stiffness and load rating could be quite a bit less.
