I got a response from Adventurer, they indicated have a 30 amp Type 1 resettable fuse in the fuse panel for both the jacks and in my case, the slide.
He said he was told by the tech's that if it trips, best to replace it, why I don't understand, but I replaced them both. I will be taking the camper on and off the truck the next two weeks, I will report back if that was a fix.
I didn't know that there were resettable ATC fuses or that there are Type 1,2 & 3 resettables. Type 1 resets itself, Type 2 resets after power is turned off, Type 3 is a manual reset.
Maybe a 30 amp fuse is not enough, but I am sure they didn't but the required wiring in that would support anything higher.
