mattyj's avatar
mattyj
Happijac issue
I’m trying to get the remote for these to work with the receiver , but No! I can get all the jacks work at once and the rear to work ok , but the fronts don’t work, I have tried connecting cable to the receiver from the remote, and to reprogram the remote, but they still don’t work, right. It’s also very difficult to find someone who will service these Jacks . Can anybody give me some help?? Thanks
  • jimh406 wrote:
    Have you tried changing the battery or moving closer to the fronts or sending unit? Have you tried manually cranking the fronts to make sure they aren't corroded?
    Other than that, I had one Atwood remote die on me at about 1 year. The second one is still going strong 15 years later. You might have to buy a new remote.
    Good luck.
    I manually cranked one of the Fronts,I will try the other and I have changed my position to be closer to the receiver, no difference, and I changed the batteries, still no good . Happijac gave me a price of $300 for a new remote. I found one on eBay for 100 but it said new/other, I didn’t like the fact that it said “other”but I bought it and i was sent the wrong remote, the model number was wrong . So when I get my refund I’m gonna try it again for the right one.
  • Have you tried changing the battery or moving closer to the fronts or sending unit? Have you tried manually cranking the fronts to make sure they aren't corroded?
    Good luck.
