DaButcher's avatar
DaButcher
Heater questions
How much do I need to take apart to clean?
Is it normal to have a brick next to the heater? The brick was there when I pulled the heater.
  • I would make the assumption that the heater was not screwed to the floor and the brick was to keep it in place? Was the heater attached?
    I have had several RV's and no brick.
    The cases of the furnace are "0" clearance and so should have no reason for brick.
  • No the brick is not normal. I would consider replacing, that's what I did with an old one of a similar type. I installed an Olympic CAT heater (8100ET, no longer made)
