LanceRKeys
Jul 05, 2020Explorer
Like stated already, you will probably be right at, or over your payload. I’m not sure how that air ride system will handle all the weight. You do have a lot of things in your favor, that Escalade is going to be long (I assume it is the suburban length and not Tahoe length), it’s heavy and you have a lot of power. Even with a transmission cooler, you will want to keep an eye on your temperature while towing, although it may never be a problem. If you upgrade something, you may want to consider LT rated tires since the Escalade probably came with P rated tires.
