Blanco1
May 06, 2017Explorer
Grit dog wrote:
^From what I just looked up, the old Lance 900 is somewhere around 3000lbs wet and loaded. If that is the case, you're looking at a whole different animal if you're talking triple slides, or even a large single slide unit. Anywhere from 4500lbs min to 6klbs on the big end.
I'm far from being the weight cops too, but I'd temper my expectations of a 20 year old pickup, even though it's a dually and try to stay on the lower end of that spectrum. Like sub 5klbs.
Plenty of roomy dry bath campers with a single slide that will fit your truck. I don't think the Mammoth or other double/triple slide campers are in your trucks wheelhouse.
IIRC the dry weight is about 25-2700, I'm not at home to go look right now, but I will.
